820-3476 green light, no boot. Weird 5V rail behaviour
Have an 820-3476 with green light. I think it had liquid damage initially but someone else has already messed with the board so i can't really tell
It has green light. Have started going down the power rail list. everything looks normal and i've stopped at the 5v rails because they are acting strange. Evertime I measure it's a different number. Sometimes it's 0, sometimes it's 2.5 and sometimes it's 5. I don't see it change when i'm holding the probes on it but when i release the probes and put them back on it's a different number again.
The thing I see that has definitely been messed with is
u7501
Shall i keep going down the power rail list or am i on the right track?
Thanks!
Post exact voltage for PPBUS_G3H.
Also post some voltages for U7501, pins 23, 13, 22, 29, 12, 21, 4.
Stable 3V42 power rail?
So SMC_PM_G2_EN is not stable; or SMC detects a problem and pull it down.
Try to start in SMC bypass mode first.
Check if SMC_RESET_L is stable.
