820-3476 green light, no boot. Weird 5V rail behaviour
kevinklinkmuller
Have an 820-3476 with green light. I think it had liquid damage initially but someone else has already messed with the board so i can't really tell
It has green light. Have started going down the power rail list. everything looks normal and i've stopped at the 5v rails because they are acting strange. Evertime I measure it's a different number. Sometimes it's 0, sometimes it's 2.5 and sometimes it's 5. I don't see it change when i'm holding the probes on it but when i release the probes and put them back on it's a different number again.
The thing I see that has definitely been messed with is
u7501
Shall i keep going down the power rail list or am i on the right track?
Thanks!
Post exact voltage for PPBUS_G3H.
Also post some voltages for U7501, pins 23, 13, 22, 29, 12, 21, 4.
Stable 3V42 power rail?
kevinklinkmuller
PPbus is 12.58v
U7501
pin 23 is 12.58
pin 13 is pulsing between 0 and 2v
pin 22 is 3.3v
pin 29 is is sometimes 0, 2.5 and 5
pin 12 pulsing between 0 and 3.3
pin 21 pulsing between 0 and 3.4
pin 4 0v
3v42 is stable at 3.4v
So SMC_PM_G2_EN is not stable; or SMC detects a problem and pull it down.
Try to start in SMC bypass mode first.
Check if SMC_RESET_L is stable.
