A1466 SSD ISSUE
Instafixx
82-00165
Device came in with intermittent hang issue.
Turned it off and now it wont turn on. Will give the question mark folder.
Green below U5110 and U8010. Replaced both. Still the same
Checked U3740 No Shorts.
P3V3SSD_VMON 0V
SSD_RESET_CONN_L 0V
SSD_CLKREQ_CONN_L 0V
SSD_PWR_EN 0.5V
Instafixx
R8070 is a No Stuff point on the board. Ran a jumper. now i get voltages and the macbook turns on detecting the SSD. Is this the permanent solution?
Also fan spinning at max continuously but nothing heats up as such.
When LID is closed it will not go to sleep and will shut down after 1 minute.
Replaced the trackpad flex just in case.
Backlight and sound go off when closing the lid?
If not, check lid signal behavior.
For the fan issue, run HWMonitor and check thermal sensors.
Instafixx
LID is okay.
Backlight and Sound go off when lid is closed.
HWMonitor shows "Memory Proximity" and "HeatPipe" at 128 C
I suppose LIO's thermal sensor is damaged; or not communicating with SMC.
If same with known good LIO board/flex, then check J9500 solders and traces; pins 5, 11, 13.
