A1466 SSD ISSUE
Check all adjacent components, following the schematic.
Pay atention to its sensors (Q5810/30/60) and their traces.
Instafixx
PCIE_CLK100M_SSD_P/N is shorted when SSD inserted and without SSD the diode reading is .300
Q5810/30/60 is readings are normal. Still replacing them just in case.
No schematic of its LIO board; use mentioned one as guide!
The thermal sensor is the same.
You don't need to identify LIO connector pins.
Instafixx
I put the machine on SMC Bypass mode (with no battery) .
The machine operated faster than normal. Can it be a SMC issue?
It can be SMC issue.
But keep in mind, SMC doesn't supervise any sensor in SMC bypass; no matter is thermal, or I/V sensor.
Did you check mentioned lines for continuity?
Instafixx
yes i did. seemed ok to me.
I installed a NEW SMC. now i need to program but this machine just refused to boot via an external drive .
The device is much faster now. only thing left is to program the SMC so that max fan spin stops
