[help]imac 21,5 a1311 820-2641! is it a kind of magic?
phantom
i don't know how to explain it....never seen a problem like this
one led
as soon as i push the power button, the led disappear.
i've discovered that the imac can boot without problem, removing the wifi card.
i've tried another wifi card: the same.
i've tried another power supply: the same
any idea????
i've found a very old thread with the same problem, apparently with no solution..
Inspect and clean J3400 slot.
Check diode mode to ground at pins 2 & 6, w/ w/o airport card inserted.
If all good, remove Q3470 and test again if starts.
All the rails derived from 1V5_S0 appear on page 6.
You should follow them and try disconnecting components, until get correct reading.
phantom
i'm going crazy, i've removed r5300 and now on pin 6 i have 0,480....
the low value remain on pp1v5_s0_cpu_mem (0,054)
i've removed r1120/r2968/r5301 but i still have an amp draw of 0,022v injecting 1v
i don't know if it is normal, but in pp3v3_s0, even with a good diode measurement, i have an amp draw (0,036) too
as soon as i remove the cpu, pp1v5_s0_cpu_mem comes to 0,180
"the low value remain on pp1v5_s0_cpu_mem (0,054)"
Did you check with RAM modules removed?
That reading depends on the actual RAM installed.
