01700 (LR350)
PP3V3_G3H_T 0v 0.337
PPBUS_G3H 12.59v 0.394
PP2V5_NAND_SSD0 0v 0.269
PP1V8_G3S 0v 0.272
PP5V_G3S 0v 0.380
PP3V3_G3H_SSD0_SNS 3.38v 0.365
Cleaned corrosion around J4802 and Q5100 before readings taken.
No corrosion found elsewhere.
Is the machine detected in DFU mode?
If not, check all AWAKE and SLPS2R voltages; small coils around U7800.
I put it back together and it works fine. The touchbar cable had a small amount of corrosion and the screen sleep sensor was badly corroded. I cleaned both. The touchbar works fine, but the sleep sensor cable is damaged.
