12" 2015 A1534 MacBook Logic Board Issue (USB Related)
OneUp
First post, subscribed to the paid service but not sure if this is where I am supposed to ask my question.
Anyway, I connected faulty electronics to my usb C port, and after an audible crack the laptop started behaving strangely. First of all, it didn't die immediately and continued to work for around 10 minutes before I connected it to a power adapter. When I connected it to a power adapter, it began freezing, so I rebooted it. It rebooted okay but during login it froze again. This happened a few more times before it wouldn't boot at all.
Eager to fix it myself, I watched several of your YouTube videos and without any real testing, I removed U700 on the basis that it seemed to be the root of most of the issues with that particular board. The chip number was 645BV which I replaced with a 645AV, convinced they were cross compatible. I verified that the charger bumped to 20V, and reassembled the laptop. Much to my surprise, the laptop booted fine, so I plugged in a usb mouse to make sure that the port was working too, which it was. At this point I gave myself a pat on the back and put the laptop to one side sure in the knowledge that it was working, or so I thought. Fast forward a week and I needed it to do a little work. I opened it up (it still had charge) and logged in, all fine. When I plugged in my USB stick it seemed to work initially and the to my horror, regressed back to freezing and not booting.
The plot thickens. Since then, I have checked that it pulls a decent current at 20V, indicating it's charging. When connected to power the interior LED illuminates and the processor heats up, indicating to me, a layperson, that the processor is busy or stuck doing something, just not booting. Because it was getting warm I decided to disconnect the battery in case of fire. When I connected the power adapter, with the battery disconnected, it jumped into life booted fine and is working, just with no battery. This seems to me like a big clue as to what's malfunctioning.
If I had to take a guess as to what it could be, based on my most recent symptoms, I would have thought it was some sort of battery management or power routing IC, but I'm no expert. Perhaps it was hanging on by a thread and the current drawn via the usb stick just pushed it over the edge. Currently it's sitting happily backing up to my time capsule, with no battery and connected to the power adapter.
Is this a common fault? If so where should I be looking and what should the test procedure include? I can provide more information if necessary.
OneUp
Thanks.
Yes it is. The board recognised the usb stick and I was able to read the data on the stick for about 20 seconds before it froze.
I had read that, I’m looking for a new laptop but I’d like to try and keep this one alive for as longas possible. Backing my data up just now.
OneUp
I don’t actually have another battery. Is there any way to verify the battery? I could connect my scope up to it while it’s connnected?
I will do th PRam in the morning and report back.
O-scope doesn't help you to check battery integrity.
Your battery has strange behaviour, need good one for test.
OneUp
O-scope doesn't help you yo check battery integrity.
New battery installed. Boots fine, USB drive doesn't seem to be causing it to cut out anymore.
Are the batteries a common issue on this model?
