2019 Macbook Pro A2141 / 820-01700-05 / No water Damage / Does not Boot / no DFU
zeydullak
On one side it is getting hot immediately which potentially be another short. Please check the pictures. Thanks.
zeydullak
On USB-C amper meter --> votlage is 20v. PPBUS_G3H is 12.61v. After about 10 seconds it goes to 12.30v and then back to 12.61 stable. U9080/580 placed on the board. Both chips there. Both chips are taken from the donor board.
zeydullak
I used a thermal camera to shoot what temperate pattern on board. So U9580 is getting warm first then the SSD chip U9400 is getting hot. Check the picture below. there are 8 SSD chips on the board and only this one is getting hot all others are quiet cold.
zeydullak
Hi there. I checked the diode mode reading from L9080 to the ground and it is 0.3029v and L9580 is 0.1275v.
I also checked these readings on a donor board and both numbers on diode mode to ground L9080/L9580 is 0.4042v. Please advise. Thanks.
You have to low reading on L9580.
At least one NAND chip got damaged; probably the one showed up on thermal camera.
