3209 trackpad
The mouse is really laggy/glitchy. you move it at it appears in a new spot, does not glide if that makes sense. works fine with usb mouse. i've replaced bottom case (keyboard, trackpad and flex cable) and still has same issue. smc reset and pram reset did not solve either.
the computer initially came in with does not power on. i did an smc reset and that fixed it, but now mouse issues. no liquid or physical damage.
Check connections from MLB to trackpad cicuitry.
This will discard bad contacts on the IPD connector...
Did you try other battery?
How it works without battery, on charger only?
Also try your USB test OSX; disconnect internal SSD.
tried with new battery and fresh os on external drive. same issue.
Pin - MLB - Trackpad
1 - 3.31 - 3.29
2- 3.29 - 3.27
3 - 0 - 0
4- 0 - 0
5- 3.09 - 3.1
6- 0 - 0
7- 0 - 0
8- 3.29 - 3.28
9- 3.29 - 3.28
10- 5.09 - 5.09
11- 3.42 - 3.42
12- 3.42 - 3.42
13- 3.42 - 3.42
14- 3.42 - 3.42
saw pin 6 is 0, so i changed u5700 and same issue. still 0v
