820–00165 as soon as the Power button is pressed fan at high speed
Good morning
it will be a very interesting experience for me, and because it is the first apple laptop that I repair.
What do you say about what TG Pro shows ?
Apple test (ATH ?) shows two mistakes
battery PPT004
fann PPPF003
fan connector:
J6000 1. PP5V_S0 5.10V
2. FAN_RT_TACH 1.62V
3. FAN_RT_PWM 4.65V
4. GND OK
Where should I start the diagnosis?
Try known goof trackpad board/flex.
If still the same, then try LIO board/flex.
Also start disconnecting webcam.
Hei 2informations
I disconnected everything and it is the same.
connected board LIO with J7000
after connecting the power supply, the fan starts after about three seconds
Is normal to have high fan spin if you disconnect trackpad and/or LIO board.
I said disconnect webcam, nothing else.
REPLACE trackpad and LIO board/flex for test...
I don't have any spare parts for this laptop I don't have any parts for apple :-(
If necessary, I will look for and buy other parts.
When the camera is disconnected, it is the same
Flex Kabel 821-1722-A
Audio DC Board
tuchpad
Bought, I will check when it comes.
If there is no improvement after replacing these elements, what next step do you suggest?
Do you mean that machine takes 5 min to turns off?
Boot USB macOS and check if same.
If yes, do PRAM reset 2-3 times.
You can also try clean ME BIOS...
If yes, do PRAM reset 2-3 times. did not help
You can also try clean ME BIOS... I have no tools to do this
I'm starting my vacation tomorrow. :cool:
vshilov
Hey, have you tried fan control? link below
at-least it will eliminate the issue of the sensor. There are resistor on the board that are responsible for fan speed control without them fan is spinning with one speed. Hope that helps.
clean ME BIOS did not help
when I turn it off, the computer still consumes electricity 0.022 A
is this normal or should it show zero ?
22mA from charger could be normal, just compare with other laptop.
3V3_S5/SUS power rails are still active.
Did you try full BIOS clean ME, or just clean ME in the backup?
