820-000165 No SSD
the board looks fine but it doesn't read SSD on U3740 pin P3V3SSD_VNOM is 0.9v I replaced the R3741 and R3742 all the other pins are fine I get 3.1v.
any suggestions?
"P3V3SSD_VNOM is 0.9v"
That voltage is correct; calculate R3741/42 divider...
Post SSD_RESET_CONN_L and SSD_CLQREQ_L.
jadao
I got trolled today with an early 2013 retina not seeing ssd, PP3V3_S0SW_SSD 3.3v was showing at both side of L3700.
But L3700 was high resistance, pratically no current flow. Replace and everything ok.
So check L700 jus in case.
pin 1 PP3v42_G3H= 3.4
pin 2 P3v3SSD_VMON= 0.98
pin 3 SSD_RESET_L = 3.4
pin 4 SSD_RESET_CONN_L = 3.4
pin 5 GRD
pin 6 SSD_PWR_EN 3,2
pin 7 SSD_CLKREQ_CONN_L= 3,2
pin 8SSD_CLKREQ_= 3,2
