820-00034-A 2 led on, fan on, no chime/screen
You've said to had steady 3V3_S5; why did you change Q7610 then?
Is not possible to get correct L7610 voltage, if Q7610 was bad.
Good 3V3_S5 implies P12V_S5 was also good.
Now you lost 12V_S5; not sure what you did...
yair37
i know, i was just check voltage at U7600 area and then the light was off and there was a short on Q7610 i was replace it and now this is the situation..no light and 12v_s5 is 3v
yair37
o.k we back to 1# LED on.
U7600
17-REG_VIN_U7600 16.6V
18- PP5V_S5 6.7V
4-REG_VCC2_U7600 6.8v
5-REG_VCC1_U7600 6.7v
24-PM_EN_REG_P5V_S4_R 0.01V diode mode 450
12-PM_EN_REG_P3V3_S5_R 11.7V :oops:
yair37
yes it was bad battery:ROFLMAO:
U7600
17-REG_VIN_U7600 12V
18- PP5V_S5 5V
4-REG_VCC2_U7600 5v
5-REG_VCC1_U7600 5v
12-PM_EN_REG_P3V3_S5_R 8.4V
I said to check totally different thing...
Be sure first LED stays on (not flashing), when trigger SMC_ONOFF_L.
