820-00045 a1534 wont turn on at all, not water damaged
ielectron
resistance on L7560 455 ohm
double checked PM_SLP_S5_L = 0V
I checked on TP first but looks like board view is a bit different than the actual main board and test point wasn't for this signal
"PM_PWRBTN_L = 1.22v"
It has strong pull up resistor (1K) to 3V3_S5.
Remove R1405 and check its level again.
Still 1.22V at PM_PWRBTN_L?
Looks like PCH issue; it should have a weak pull-up resistor inside.
Do you get AVREF_SMC voltage?
