820-00138 - not charging - magsafe green light blink [SOLVED]
"PPBUS_G3H on F7700 - 16.21V - without battery connected"
Are you sure???
If yes, change Q7130.
Be sure C7125 is good.
nameless
oh sorry 20V with 85W charger and 16.21V with 60W charger
checked Q7130 getting 20V with 85W charger
C7125 wasn't sure if good so replaced from donor
Went from 1.3 mohms to 0.5 mohms
nameless
btw i'm getting fluctuating voltage on pin 1 on U7100 (w/wo chip) from 0 up to 9V (15V on donor board)
nameless
thanks for your reply
I removed the Q7130 and it was shorted indeed ))
I ordered a new part https://www.mouser.fr/ProductDetail/863-NVTFS4C06NWFTAG
Which I received but its too small ))
Here some pics
Do you know where can I get this part ? cause the donor board doesn't have the same and I can't find the same specs
Thank you
Best regards
You can get it from normal laptop boards too (not Apple only).
The high-side MOSFET from any CPU/GPU power supply is more than you need; just pick the correct package.
nameless
lol thanks for your support ))
took it from HP mb and booom
where can i mark as SOLVED !!
