820-00138 turns on, battery error symbol, then turns off. Works fine in SMC bypass
U7100
pin 9 - 0.030v
pin 15 - 0.065v
As i was measuring this, the R7020 blew up. I think i might've plugged in the charger wrong because there's no green light. have replaced it with another resister with the same marking "470" but still no green light. What did i do :(
R7020 usually gets burnt because of short in U7090, or one of the filter caps from its pin 6.
Seems to be U7090 in this case.
Also check for short, or low value at 3V42 rail; before and after U7090 is removed.
before and after removal the 3v42 rails are quite low. 10 ohms short to ground, so must be a cap, should i inject voltage and see what heats?
I don't think that.
Something else happened there.
Unless you used fake charger, which gives full voltage always.
Original Apple Magsafe 2 gives only 3V at the first moment, before the board is detected correctly.
Bench power supply also can generate such kind of problem.
Every day can learn a lesson; but sometime can be pricely...
Next time when you use bench power supply, set it at 3V and go high to nominal voltage after Magsafe is correctly connected.
Did you get it from same model donor board?
Machine should start in SMC bypass, as before.
Something went wrong in the process, or SMC is bad/incorrect.
Also check SMC_AVREF voltage.
Actually, it wasn't from the same model donor. the chip has the same markings. I guess you're going to tell me now that the programming is different hahaha
I can't find SMC_AVREF in the schematic or board view
"I can't find SMC_AVREF"
PP3V3_S5_AVREF_SMC to be more specific.
"I guess you're going to tell me now that the programming is different"
Exactly!!!
Hi there! Revisiting this today. Bought donor board and have reablled SMC from a 820-00138-a board but I noticed the board i'm repairing is 820-00138-05
have tested that SMC and while I get the orange / green light and while the light turns screen when i try SMC bypass, it's not doing anything more than that :(
Will these SMC's work?
