820-001598 SSD Upgrade
mushr00m
It doesnt go automatically to recovery!!
I am able to put in DFU using the keyboard!
I am not forcing SE032 anymore with keyboard it goes to DFU!
SSD is still suspect, if you can't complete DFU.
People on Internet mentioned they succeed after several tries/days.
Did you try flashing U4770?
mushr00m
Would you replace with original SSD nand and try DFU restore?
I already tried more than 10 times DFU restore with 512GB SSD (4 nands resoldered)
No I did not
You can try that too.
Be aware, the board was heated several times.
You should understand that there be something else damaged.
mushr00m
What and where and how to look for something damaged?
I do not think that heating sometimes with enough heat to make it melt and solder a NAND would make the machine defective!
You can't be sure about the new NANDs also.
But machine should work with its original NANDs.
If not, what explication can you find, else than more damage on the board?
mushr00m
Just put the original NAND and machine is working perfectly
I think I am not going to solder again all of these 4 chips. I think they have problem and/or I soldered bad it twice and it did not worked out
Would you make a last try or since its back to life and I heated a lot the board with all of those NANDS.. give it back to customer saying not possible to upgrade at this time
Possibly got bad NANDs, or you didn't solder them in the correct place.
If you have stock of scrap boards, then buy P13 programmer and prepare yourself the NANDs extracted from these boards.
mushr00m
To be honest with you I removed and resolder twice really think its hard to solder it bad twice.
The supplier from aliexpress told me he tested before send but anyhow.
But the question here is would you give it back original do customer and cancel the service/profit or would you tell him that we are going to make another try with those NANDS and with so much heat the machine could stop working and if it happens I do not give him any warrany?
Let me know how would you proceed
