820-0016 MISSING PM_BATLOW_L
huzeafa
Good day guys
am currently busy on a board, and I am struggling to get the PM_BATLOW_L signal, I have replaced the known good SMC but no changes, the same SMC works okay on a different board and I get PM_BATLOW_L, but on this board, I don't have it, other SMC output signals are present and my ppbus voltage is properly regulated by the SMC too. I checked for a short to ground and there's non, is there somewhere I need to check for this signal? without the signal being created, am unable to move forward, please help.
Be sure to use original Magsafe 2 charger; no matters 45-85W.
Do you get amber light and battery is charging?
Steady 3V3_S5/SUS?
Check R1410...
huzeafa
@2informaticos, 3V3_S5/SUS is steady, R1410 has 3.3V on pin 1 but less than 1V on pin 2, when I disconnect the resistor from the PM_BATLOW_L line , i got 3.3V and there's no short to ground
"Do you get amber light and battery is charging?"
Try to start with charger and battery, both connected.
huzeafa
Thank you guys, I apologize, for my mistakes, when @2informaticos asked this (3V3_S5/SUS is steady) I did check but did not hold the probe point longer to see that after sometimes the voltage drops and then go back up, so I resolved that, and the board is now resolved.
Thank you so much @2informaticos and @Gurmon.
