Hello,
I have a 820-00163 that powers on with a fan spin, but nothing else. Customer said it just suddenly stopped working. No corrosion found, board looks clean.
PPBUS_G3H = 12.6 volts
PPVCC_S0_CPU_PH1 = 1.8 volts
PPVCC_S0_CPU_PH2 = 1.8 volts
PPVCC_S0_CPU_PH3 = 1.8 volts
PPVCORE_S0_GFX_PH1 = 0.85 volts
PPVCORE_S0_GFX_PH2 = 0.85 volts
BIOS
1 SPI_MLBROM_CS_L = 3.3 volts
2 SPI_MLB_IO1_WP_L = 3.3 volts
3 SPI_MLB_IO2_WP_L = 3.3 volts
4 GND
5 SPI_MLB_IO0_MOSI = 0 volts ?
6 SPI_MLB_CLK = 0 volts ?
7 SPI_MLB_IO3_HOLD_L = 3.3 volts
8 PP3V3_SUS = 3.3 volts
When I plug in the power adaptor, pin 5 and 6 pulses two times to 0.5 - 1 volt and then goes to 0 volts
R6122 / SPI_MOSI / pin 1 = 0.474 diode mode
R6121 / SPI_CLK / pin 1 = 0.474 diode mode
R6111 / SPI_CLK_R / pin 1 = 0 volts / 0.48 diode mode~
R6112 / SPI_MOSI_R / pin 1 = 0 volts / 0.48 diode mode~
How should I proceed in troubleshooting this board?
Thank you in advance.
BIOS
4 GND
