820-00165-A Green Light NO Power
Hello,
I have this 00165
Initial status:
-Liquid damage around R7523, R7520 and R7521 (Close to U7501).
-PP3V42_G3H shorted to ground due to bad SMC.
Repairs:
-R7523, R7520 and R7521: replaced
-SMC Replaced
Current Status
-PP3V42_G3H: 3.42V
-PPBUS_G3H: 8.60V
-PP3V3_S5_REG_R: 3.3V
-PP5V_S4RS3: 0V (I have 5V for 200ms)
-Green light for a moment and then orange light.
I alredy replaced U7501 and PP5V still 0V. (When replacing U7501 PP3V3 started to pulse, so I return the original U7501).
Do you get one, or two pulses at L7520, when connect charger?
Check at other big coils at same moment.
Can you catch pulse at L7520 when trigger SMC_ONOFF_L?
Try to start in SMC bypass mode...
After measuring what you mentioned I noticed I have 0.2ohm to ground on L7320 and L7310
-PPVCC_S0_CPU_PH2: I have 1.7v for 40mS.
Dead CPU? :/
Should I try Inject voltage?
Ultrasonic cleaner?
Dead CPU then.
This board should have approx 8-15 ohm there; depending the CPU type and multimeter used.
