820 - 00165 A liquid damage, green light but no fan spin no boot
Bath submerged macbook air,
Obvious damage to the backlight circuit and both the lcd connector on the board as well as the lcd cable.
Put through crest, replaced dodgy looking bits in the backlight circuit, changed the lcd connector.
New io board and flex.
When I plug it in with only lcd and ssd connected, I get green light but nothing else
Also not sure about the keyboard, I am guessing there a pins I can short to turn the power on, tried a few that are labeled smc on but no difference
Test the board alone, only 5 pins DC cable connected.
It should start automatically when charger is connected.
Try first to start in SMC bypass mode.
Post SMC_ADAPTER_EN, PM_BATLOW_L, PM_SLP_SUS_L, 3V3_S5, 3V3_SUS.
OK, no green light for some reason when I left only the 5pins in.
SMC_ADAPTER_EN 0v
PM_BATLOW_L 0v
PM_SLP_SUS_L 0v
3V3_S5 0v
3V3_SUS 0v
I was checking a few other things
g3h is 8.2v
U5110 lloks a bit dodgy and few smaller bits around it
"no green light for some reason"
Of course, no LIO flex connected.
You don't need the light at this moment.
Confirm if you really have 3V at SMC_RESET_L.
Do you get 3V at both pins 5/8 of U5110?
If missing SMC_PM_G2_EN, you may need to reball SMC.
Reflow it with good flux first...
Don't torture SMC yet!!!
"U5110 lloks a bit dodgy and few smaller bits around it"
Clean its area, resolder, change corroded components...
"I get green light"
With SMC_RESET_L at 0V???
Cheers
I redone the U5110 and the bits around yesterday
Yes, I still get the green light when the flex cable is connected.
Checked SMC_RESET_L with and without flex cable, still 0v, I checked on 2 points far away from each other
Tried reflowing SMC, 200 Celsius with my quick 861da and mg chemicals flux but no difference :/
Missing SMC_RESET_L blocks the SMC.
Strange to get Magsafe light in this case; maybe fake charger used...
You MUST get steady high level at SMC_RESET_L to continue.
Check resistance to ground there.
Be sure R5100 is good.
Remove U5110 and check voltage level.
Remove R7100 and check again.
Also clean/remove J6100.
Then only SMC remains to change; try reflow it first...
R5100 comes up as 96.7k omhs so it seems fine
removed the u5110 and I am getting 3.4v SMC_RESET_L - looks like good direction
SMC_PM_G2_EN 3.4v
the pads for u5110, pad 5 3.4v, pad 8 0.42v ( thats without u5110 in place)
SMC_ADAPTER_EN 3.44v
PM_BATLOW_L 0.03v
PM_SLP_SUS_L 3.32v
PP3V3_S5 3.32v
PP3V3_SUS 3.32v
I guess I need a new U5110, right?
JohnB8812
Your problem is also going to be the battery after you fix PPBUS so definitely get a known good OEM 85 Watt Magsafe 2
