Initially wouldn't turn on , Ran through ultrasonic cleaner now I am here. No more visible liquid or corrosion on board.
Current issues - Loud Fan Spin + Slow / Laggy Operation
Everything Else Works Fine.
From what I can tell I need to run an "MRI" test as ASD is not available for the 2015 MacBook Airs to determine which sensor(s) are failing.
Using standard hardware test shows:"may be an issue with smc - PFM006, may be an issue with power management system - PPN001
How can I run an "MRI" test?
Any help is much appreciated - thank you!!
