820-00165-A NO Green light MacBook Air A1466
zockysworkshop
It is small water damage in the U7090 area. C7094 was missing i put another cap im getting PP3V42_G3H also SMC_BC_ACOK is present and SMC_RESET_L is 3.3v i think all signals are present for the computer to get green light bu i don't have green light. At some point while C7094 was missing i got green light but board wouldn't turn on after i put the C7094 i lost the green light also the Voltage that im getting is 7.3V that's P3V42G3H_BOOST, also the via for P3V42G3H_BOOST was damaged from pin 3 of U7090 to pin 1 of C7094. Any ideas???
zockysworkshop
All areas on the board are super clean just around U7090, so i just plug the same charger to my 15 inch macbook pro retina display and when i got green light i plug back to the board im working on and i get also green light but computer doesn't power if i plug the charger in my retina macbook and get orange light when i plug back to the air is stays orange but no fan spin
larossmann
This is cheating, you should have light on the charger just plugging it into the air! Answer my questions.
zockysworkshop
PP5V_S5 is missing i check U7501 i have voltage only on Pin 23 VIN that's PPBUS_S5_HS_OTHER_ISNS and pin 22 P5VP3V3_VREG3 the enable signals on pins 12, 21 and 4 they are all missing and that leads me to the SMC am I right ?
zockysworkshop
larossmann
SMC_PM_G2_EN is required for PP5V_S5 and this does come from the SMC.
You still haven't answered my questions from my first post in this thread. I can't help you if you can't answer me. PP3V42_G3H ripple can kill the SMC but I am not jumping to this conclusion based on not having any information. Give me the information I asked for!!
zockysworkshop
I removed the filling around the SMC and i reflow the SMC that solve my problem thank you for your help Louis i appritiate it .
