How can you explain different voltage on the pins of "not blown" fuse???
Continuity mode not always shows bad fuse.
I faced with this problem, after found shorted cap into CPU power supply.
Fuse showed good in diode mode, but machine spins fan 1-2s, or turned off after 10s; fixed replacing the fuse.
