820-00165 a1466 no power
no sign of corossion.
with battery charger connected only green light
without battery charger connected got green/orange light.
when press power button fan spins 1sec.
tried smc bypass can see the apple logo then it shutsdown
ppbus_g3h 8.16v
u7100
17-18 27-28 normal
1 - 0.004v
2- 16.1v
3 - 4.3v
9 - 0v
12 - 3.4v
13 - 3.4v
14 - 3.305v
15 - 0.v
17 - 8.1v
19 - 5v
20 - 5v
25 - 12.5v
27 - 15.9v
smc_onoff_l 3.4v
smc_reset_l 3.4v
plt_reset_ l ov
y5110
osci frequency is up n down.
Check voltage and diode mode to ground on SCL/SDA lines of battery bus.
Did you try known good LIO board/flex?
In SMC bypass mode, test the machine with USB macOS.
SDA is 0.735 3.4v stable
SLC is 0.735 2.8-3.4v pulsing.
LIO board/flex? nothing changes.
it is actually can turn on can go to the menu but it shutsdown itself most of the time when u turn on
fan spins for 1sec. then off again
ppbus with battery only is 8.44v
Test the board alone on the desk; nothing connected, no TP, nor LIO flex, only charger.
Board should start by itself, when charger is plugged in.
Remove SSD and airport card too.
Try known good battery.
PPBUS_G3H is 8.19V with charger alone, no battery?
Reball SMC; if no change, replace it.
