820-00165 ALL_SYS_PWRGD 0V
No-Clean
Board had little corrosion on C2740 and C7825 other than that board is clean.
PPBUS 8.6V
PP5V_S5 5V
3V3_S5/SUS 3.3V
PLT_RESET_L 0V
ALL_SYS_PWRGD 0V I get around 3V for a few seconds after I plug the charger.
Which big coils get voltage?
Inspect U1950 for corrosion; remove it and resolder.
Also test desoldering Q8150.
No-Clean
U1950 was clean but replaced it regardless, also removed Q8150 after replacing U1950 and same result.
Only L7130 and L7560 get voltage.
"ALL_SYS_PWRGD 0V I get around 3V for a few seconds after I plug the charger."
Which other voltages (big coils) appear at same time?
Also check U1950 pins in these few seconds.
No-Clean
All big coils get voltage for about 1 second, even vcore comes up.
U1950
Pin 8 steady 3.4V
All other pins pulse for about 1 second.
Any pulse at PLT_RESET_L?
If not, check at CPU_VCCST_PWRGD and CPU_VR_READY.
Check all SPI Bus Termination resistors and their traces.
Inspetc J/U6100 for corrosion.
No-Clean
PLT_RESET_L 0V no pulse
CPU_VCCST_PWRGD and CPU_VR_READY both pulse around 1V
J/U6100 are both perfect.
SPI Bus Termination resistors and their traces look perfect too.
Heat CPU/PCH with quality flux.
Is possible to have accumulated crap underneath.
Just in case, test first starting in SMC bypass mode.
