iambehr
Hello,
Feeling stumped on this one. No backlight.
Fuse at F7700 OK. U7701 backlight driver was shorted to ground.
No voltage getting past Q7706 at all. Voltage at pin 4 of Q7706 is 9.83 volts. Pin 3 is at 9.55 volts.
Resistance at R7788 is 300K. C7782 is not shorted open. Pins 1,2,5,6 are at 0 volts.
I replaced the backlight driver IC U7701. Figured that Q7706 was bad and replaced, along with R7788 and C7782.
Removed R7789 temporarily to isolate the MOSFET and still 0 volts on output.
I am stumped. Voltage on pin 3 should be much lower than pin 4 for the gate to function I believe, but I cant seem to find what I am missing.
Any ideas?
Thanks,
Stefan
Any ideas?
Thanks,
Stefan
