820-00165 Backlight Again
iambehr
Hello,
Feeling stumped on this one. No backlight.
Fuse at F7700 OK. U7701 backlight driver was shorted to ground.
No voltage getting past Q7706 at all. Voltage at pin 4 of Q7706 is 9.83 volts. Pin 3 is at 9.55 volts.
Resistance at R7788 is 300K. C7782 is not shorted open. Pins 1,2,5,6 are at 0 volts.
I replaced the backlight driver IC U7701. Figured that Q7706 was bad and replaced, along with R7788 and C7782.
Removed R7789 temporarily to isolate the MOSFET and still 0 volts on output.
I am stumped. Voltage on pin 3 should be much lower than pin 4 for the gate to function I believe, but I cant seem to find what I am missing.
Any ideas?
Thanks,
Stefan
Well, shoot. Pin # 5 EDP_BKLT_EN is shorted to ground.
Removed Q7707 and retested to be sure.
Pretty sure this is done then.
Cleaning in ultrasonic just in case I am extra lucky, but I doubt it.
Thanks,
Stefan
