820-00165 Backlight
CRC2018
Having an absolute nightmare trying to restore backlight to an 820-00165 which was liquid damaged. I had a small around of corrosion around the LCD connector which has cleaned up fine - most of the corrosion was around the backlight driver U7701 and its accompanying resistors. Having pulled the backlight driver and confirmed it looked burned out under the microscope have checked all pads underneath the backlight driver were connected to where they should be. Found all were connected with the following exceptions - Pin 12 wasn't connected to R7741 so i've scratched and fixed that, same with pin 8 and r7714. I've also replaced a couple of resistors next to U7701 as they were not reading correctly. Can also confirm Feedback Pin #5 is connected to pin 2 of D7701 - i've seen that line be blown before but not this time!
Observations -
Getting around 3.3v on EDP_BKLT_EN
Getting 0v on LCDBKLT_EN_L
Getting 2.8V on LCDBKLT_EN_DIV_L
Getting PPBUS voltage or 8.5V on LCDBKLT_BOOST, PPHV_S0SW_LCDBKLT
Resistors for LED_RETURN1,2,3,4,5,6 are all reading 0hms and connected to LCD Connector.
Tried another screen same result.
I think i've covered everything i've tried but is there something i've missed - should also add i've tried now 3 new LP8550 drivers and i'm getting the same behavior with each which leads me to conclude that either im very unlucky and have a faulty batch of LED drivers or i've missed something!
You didn't mention anything about image presence.
What about BKL_PWM/EN levels?
Did you try PRAM reset?
Post diode mode (red probe at ground) on both pins of D7701 and all return resistors.
CRC2018
Hi
Thanks for your suggestion! BKL_EN was 0V traced the problem down to the Pad under R7731 was corroded - not at all visible from the top! have since repaired the pad and put a new 200k resistor there and now backlight restored!
