820-00165 Board fan spin, but no image
Neil250
Originally, short on PP3V42_G3H with corrosion on C5002, C5007 and C5008
These were replaced.
Short gone.
Green light on charger, fan spin. No image.
PRAM reset. Nochange.
PPBUS_G3H: 8.58V
L7310: 1.80
L7320: 1.80V
L7430: 1.20
L7560: 3.36
L7520: 5.16
L7130: 8.58
L3095:
PIN1: 0V
PIN2: 0V
C3080:
1: 8.58
2: 8.19
R3080: 465 Ohms
L7701:
1:0V
No short by ohm mesurement on L7701
F7700 Fuse is good
Q7706
4:8.58
3: 8.32
1: 0V and no short
Q7707
EDP_BKLT_EN: 0V
BKLT_PLT_RST_L: 3.2V
Replace U7701?. NO change
USB port lights up a USB hub.
Neil250
3.35V on PLT_RESET_L
U1950 looks good
looking at Q3080:
PIN 4: 8.57
PIN 1: 8.19
PIN 2: 0V
PP5V_s5: 5.15
PP3V3_S4: 3.35
PP3V3_S3: 3.36
pp3V3_s0: 0V
PP5V_S4RS3: 5.15
PP3V3_s5: 3.35
PP3V3_SUS: 3.35
PP3V3_S4SW: 3.35
Do you get USB actibvity?
Check it properly, not only for 5V on USB port.
Caps Lock reacts?
Try known good BIOS, just in case.
Neil250
cpu is warm
how do i check the usb.
I plugged in a mouse, it does not light up and stay on but it does briefly flash when plugged in.
