Getting back to this board.. I'm getting a green light then amber, no fan. Check R7006 for V and immediately get fan spin for 12 seconds on, off, 12 seconds on, off - USB mouse light on the whole time until i remove probes. Same with R7005. Same with meter off.
Hit the SMC with some heat/ flux. Power supply and 3 different chargers, known good DC-in and cable.
R7005 is on PPBUS feeding 3V42 circuit. I see no reason why the board would power on when touching this. I also see no reason to measure anything there as green/orange light is present so 3V42 must be present. R7006 is not in the schematic. Check what you are measuring.
See image for R7006.
I've had this resistor be the issue with a lot of MBA's. Some even with the light. I always start there to see what I'm getting...
Oops, I was looking at the 3476 schematic. Still no idea why it would power on when touching that. Is 3V42 present and stable? Crap under the SMC is still suspect.
