820-00165 CRAZY NO BACKLIGHT Issue
Bouba148
Hi 2Informaticos; team
No Backlight
Tested with another known good screen : same
Display works fine on an external TV through a thunderbolt hdmi adapter
LCD not detected
Backlight flashes once when hearing chime
SMC not talking to the LCD:
SMBUS_SMC_0_S0_SDA and SMBUS_SMC_0_S0_SCL solid 3.3V
DP_INT_HPD: 2.67V in diode mode 0.460V
checked all capacitors and resitances on the LCD path
EDP_PANEL_PWR: 3.318V and solid just after the chime
As I've noticed that NO green light and NO keyboard
So I've suspected the SMC
Reflowed the SMC: same
Checked the bios with the Medusa, all the different parameters are looking fine and doesn't make me think about an SPI issue
I was OUT of Idea; so I took the other issues under consideration first, then I decided to check and focus on the green light
So I've disconnected the flex LIO board:
Backlight came back as well as the keyboard. CRAZY
Replaced both flex and LIO board: same
So wondering about USB issue shooting down the others signals
Plugged an USB mouse on the Motherboard USB port with the Flex disconnected : NO Activity
So now should I focus more on the USB Level or more on J9500?
Best Regards
"Replaced both flex and LIO board: same"
Looks like bad LIO connector (J9500) on the MLB.
Inspect it under microscope.
Check SMC_LID voltage w/ and w/o LIO flex connected.
If it goes down, TP/KB is disabled.
Be sure R5171 is OK.
Of course, do NOT use Magsafe adaptor 1-->2!!!
Bouba148
Of course, do NOT use Magsafe adaptor 1-->2!!!:
YES SURE, I only une official 85W cables (magesafe 1 and 2 ) connected to Lab Power Supply
SMC_BC_ACOK: 3.387V
SYS_ONEWIRE: wave with peak to peak : 1.50V it should be 3.3V no?
Adapter sense: 1.5V also
Strange no? knowing that I already tried another Flex and LIO board.
What could create that drop of half of voltage....hummmm?
I'll try to run a wire directly from SYS_ONEWIRE of LIO to the test point near the SMC
Adapter Sense
SYS_ONEWIRE:
If the signal (1-wire protocol) is the same on both lines, U6900 (from LIO board) works.
You must get aprox 3V DC on multimeter.
"Check SMC_LID voltage w/ and w/o LIO flex connected.
Be sure R5171 is OK."
JohnB8812
Replacing is not a bad idea. Those pins being corroded always causes issues make SURE the pins of the connector are soldered properly.
Bouba148
Replaced LIO j9500 Connector: Problem Fixed
Backlight, Green/Orange Led, keyboard, Sound, USB Port ALL OK
Thanks 2Informaticos
You can set this topic as RESOLVED
Best Regards
