820-00165 Doesnt Boot. Green Under SMC
Check diode mode to ground on that corroded line.
Be sure R5117 has correct ohm value; it requires 3V42 presence on the other pin.
Did you resolder correctly SMC?
Use leaded paste for balls.
Check if machine starts in SMC bypass.
Do you get voltage on CPU core coils?
PLT_RESET_L comes high?
Inspect for corrosion all SPI Bus Termination resistors and their traces.
Clean J6100, if needed.
Instafixx
Removed the SMC and checked all the PADs. The top 3 lines diode mode readings are totally out of range barring 2-3 pads.
Example
SMC_OTHER_HI_ISENSE is 0
SMC_CPUVR_ADJUST_ISENSE is 7.7.
SMC_TDO is 2.7
The upper portion of the SMC had the green corrosion.
Do we have to reconstruct all these traces ?
