820-00165 doesn't power on with magsafe
Test the board alone on the desk, without LIO flex, nor trackpad, SSD, or airport card.
Use R5115/16 pads to trigger SMC_ONOFF_L, instead of power button.
Also keep the battery disconnected for the moment.
jadao
Hello 2informaticos, I did an ultrasonic but no change.
I tested it without flex and nothing else plugged in, only original magsafe 85w and it starts as expected without the green line.
Then I trigger SMC_ONOFF_L to shut it down and power it on: it will start sometimes but not consistently...
sometimes it will simply not start even if SMC_ONOFF_L is going low.
Post exact voltage for 3V42_G3H, PPBUS_G3H and SMC_ONOFF_L, when doesn't start.
Check if always starts in SMC bypass mode.
jadao
Ok so when it doesn't start: PP3V42_G3H is 3.422V, SMC_ONOFF_L is 3.419V and PPBUS_G3H is 8.59V.
However, SMC bypass mode simply doesn't work! I missed it since the board boots normally and works I didn't try it!
I tried also smc bypass with LIO flex to monitor the magsafe LED, the led stay off but no fan spin.
The magsafe led is on, green then orange in normal mode...
Be sure PM_RSMRST_L is steady high.
Replace R5100; try 33-47K, instead of 100K.
If you detect drop pulse at PM_PWRBTN_L, when trigger SMC_ONOFF_L, then check for pulse at all PM_SLP_Sx_L signals at same time.
Check PM_BATLOW_L, PM_DSW_PWRGD, 3V3_SUS.
Remember, all the tests when board doesn't want to start...
jadao
PM_RSMRST_L is steady high at 3.3V
Replaced R5100 with a 35k but nothing changed.
Yes I detect drop pulse at PM_PWRBTN_L, when SMC_ONOFF_L is triggered, I check for PM_SLP_S5 and found it missing 0V.
Checked PM_BATLOW_L 3.32V , PM_DSW_PWRGD 3.41V and 3V3_SUS 3.3V.
Yes all the tests done when board doesn't want to start.
Thanks
Looks like PCH issue.
No pulse at all at PM_SLP_S4_L, when trigger SMC_ONOFF_L?
Check PCH_DSWVRMEN and the 4 RTC signals.
You may need to put quality flux and heat PCH/CPU area; trying to burn eventually accumulated crap.
jadao
No I had no pulse at PM_SLP_S4_L when SMC_ONOFF_L was triggered.
PCH_DSWVRMEN present and the 4 RTC signal are present (checked them in the beginning but didn’t reported them).
I heated the PCH with flux but no change, probably still crap or an issue.
I returned the machine to the customer, he accepted it as-is. If the issue happens he will only have to unplug the magsafe and it will turn on when he press the power button.
thank you very much 2informaticos
