This logicboard had water damage causing backlight issue, crap near SMC and ISL6259 but no heavy damaged components.
Cleaned everything reflowed SMC to make sure.
At this point, it boots all ok with battery, it charges when magsafe is plugged in. AHT test doesn't show any error.
It will start as expected automatically with the charger when the battery have been previously disconnected.
The problem is the second time when I power off the board with the charger still connected it will not power on after pressing the power button.
I have to disconnect the magsafe and it will power on from the battery when I press power button, if I put back the magsafe it will charge fine but again if I power off and press again the power button it won't start.
This looked to me initially a piece of cake but now I am completely stumped!
PPBUS is 8,56V without battery charged
3,42V PP3V42 present
SMC_reset_L is a nice 3.3V
SMC_ONOFF_L is also 3,4V
I can see SMC_ONOFF_L going low to 0,4V when I press power button.
PM_PWRBTN_L is also 3.4V and goes low when I press power button.
Resistance between pins 17-18 is 4 ohms and 24ohms between 27-28.
R7005 and R7006 are respectively 10 and 5 ohms I get the proper voltage on D7005 output either 8.56V either 16.5V
I replaced D7005, replaced U7100, replaced U5110, replaced Q7180 and Q7130, reballed original SMC then replaced it twice and still have the same issue...
Tried different keyboard/trackpad original 85w magsafe, I/O board & cable.
Checked again and compared expected values coming in and out of U5110 and they check fine.
The only clue I can tell is that SMC_reset_L is sensitive as soon as I probe it in voltage mode it will trigger the board and it starts, I have no more logical explanation for this as I reballed and changed twice the smc, changed the ISL and checked all traces for SMC_RESET_L. I will try an ultrasonic in case some crap under the cpu.
What am I missing or what can I check? I have no more idea and am exhausted on this one.
Thanks
Thanks
