820-00165 green/orange light, no fan spin. SMC bypass works!
Hi there!
Have 820-00165 green/orange light, no fan spin. SMC bypass works. Was pretty corroded in some places. thought i'd try my luck with the ultra sonic but same issue
So must be a sensor as I understand it?
thanks!
I should mention, before it died the customer told me that it would only work with power supply plugged in. Would cut out as soon as it's disconnected.
Charger only:
pin 2 = 20v
pin 3 = 5.3v
pin 9 = 0.03
pin 12 = 3.4
pin 13 = 3.3
pin 15 = 0.06
pin 26 = 19.26v
Same result with battery and charger connected
Pin 17/18 3.3 ohms
pins 27/28 20 ohms (seems high?)
3v42 is 3.4v on battery
PPBUS_G3H 7.3v on battery
Are you using original Apple Magsafe 2 charger?
Input voltage is too high even for 85W charger.
Try a known good one, 60W if possible.
AVREF_SMC is good at 3.3
Nothing at PBUS_S0_VSENSE because there's no SMC_sensor_PWR_EN
DCIN_S5_VSENSE is 2.8V
SMC_CPU_VSENSE 0V
SMC_P1V05S0_VSENSE 0V (I'm guessing all S0 are down for obvious reasons)
SMC_CPUDDR_ISENSE 0V
SMC_P3V3S5_ISENSE 0V
How would it be possible to check sensors that rely on S0 rails if the machine isn't turning on hmmmm
SMC_DCIN_VSENSE is now OK.
Check SMC_DCIN_ISENSE and SMC_BMON_ISENSE.
No pulse at all at L7520 when SMC_ONOFF_L is triggered?
It should pulse at least, when SMC_ONOFF_L is triggered.
Check first if PM_PWRBTN_L reacts.
"retesting with orignal chargere"
Original Magsafe 2???
You can use bench power supply, with Magsafe 2 cable only.
Never test with Magsafe 1-->2 adapter.
