820-00165 Macbook Air No Fan Spin
Instafixx
Customer says it is repaired before but i couldnt find any traces of any work done. No Corossion as well.
PPBUS is 8.58V
PP3v42 present.
I noticed that U8020 is a but chipped off from the corner but all voltages are stable.
U8040 also same . Chipped Off. But here all Voltages are zero. (Checking Bare Board on Bench.)
"here all Voltages are zero"
Where exactly?
Check Q6060 voltages and diode mode readings.
Compare with good board.
Did you try known good fan?
You've just said "no fan".
I supposed to have an working machine, just no fan spinning.
Do you get 3V3_S5/SUS?
Looks like PCH issue.
Check PM_BATLOW_L, SMC_ADAPTER_EN, PM_DSW_PWRGD, PCH_DSWVRMEN and the 4 PCH's RTC signals.
Just in case, test SMC bypass...
UPDATE - Spoke to the customer and the shop he got it repaired from somewhere. They had replaced U7701 a month back. But the i checked that area.It looked okay to me.
Should we go for PCH ?
