820-00165 MBA, only missing bluetooth
Neil250
U3510
1: 0 V
4:3.32 V
5:3.32 V
Tried another airport card off ebay
Continuity using diode mode
10 and J3501 PIN 17: GOOD so my jumper looks good
9 and J3501 PIN 16: GOOD
Check voltage and diode mode readings on pins 6/7 and 9/10.
You can also remove U3510 and bypass these pins...
Neil250
Can you explain what you mean by:
VOLTAGES:
6: 0
7: 0
9: 0
10: 0
4: 3.4
5: 3.4
That can't be good.
DIODE:
6: 0.40V
7: 0.40V
10: 0V
9: 0.70V
So you have 29 ohm to ground at USB_BT_CONN_P?
"10: 0V"
Does this mean 0.000 in diode mode?
I was expecting 0.015-0.030 in diode mode, for 29 ohm...
Check there removing airport card too.
BTW, you didn't put "V" for voltage, but for diode mode; any reason for that???
Always post diode mode in format xxx, if less than 1.000; we will understand 0.xxx for sure (no V needed).
