So you have 29 ohm to ground at USB_BT_CONN_P?
"10: 0V"
Does this mean 0.000 in diode mode?
I was expecting 0.015-0.030 in diode mode, for 29 ohm...
Check there removing airport card too.
BTW, you didn't put "V" for voltage, but for diode mode; any reason for that???
Always post diode mode in format xxx, if less than 1.000; we will understand 0.xxx for sure (no V needed).
