820-00165 missing PM_SLP_S4_L
jadao
This one has no liquid, is clean and just died one day on its own. Customer powered it off and it never powered on again.
I 've checked all these signals for PM_SL_S4_L and they are present.
PPVRTC_G3H
RTC_RESET_L
PCH_SRTCRST_L
PCH_INTVRMEN
PCH_DSWVRMEN
PCH_CLK32K_RTCX1
PP3V3_S5
PM_DSW_PWRGD
PP3V3_SUS
PM_BATLOW_L
PM_RSMRST_L
PM_PWRBTN_L
When I plug magsafe CPU_VCORE apears or pulses briefly twice and stay at 0V after. Same thing with ALL_SYS_PWRGD and SMC_DELAYED_PWRGD.
If I trigger SMC_ONOFF_L, CPU_VCORE will pulse only once.
If I do an smc bypass, I see the fan spins twice and stop :eek::eek::eek:
Is there any hope I can check something else or most likely a PCH issue? Especially that i have no liquid damage...
Thanks
Pulsing twice, is the worst repair scenario for this board.
Check if all voltages on pages 11 & 58 try to appear too.
For tests, start first in SMC bypass, then trigger SMC_ONOFF_L for voltage checkings.
This gives you a bit more time to catch the pulses.
I recovered several boards heating CPU/PCH with quality flux.
Should insist more on PCH area.
jadao
Thanks for the tip, it works very well with smc bypass and a wire soldered on SMC_ONOFF_L.
All voltages on pages 11 and 58 try to appear, I noted the values below.
I tried heating PCH with flux but didn't change anything...
Page 11
PP3V3_S5=3.3V
PP3V3_SUS=3.3V
PP3V3_S0= Pulses to 3.3V and goes back to 0,099V
PP1V5_S0SW_AUDIO_HDA= pulses to 1.5V and goes back to 0V
PP1V05_S0=pulses to 1.05V also at R1280-pin2, L1275-pin2 and L1270-pin2 and goes back to 0.005V
PP1V05_S0SW_PCH_HSIO=pulses to 1.05v also at L1290-Pin2 and L1295-pin2 and goes back to 0.005V
Page 58
PP1V5_S0= pulses to 1.5V and goes back to 0V
PP3V3_S4=Pulses to 3.3V and goes back to 0,34V
PP3V3_S3=Pulses to 3.3V and goes back to 0,48V
PP3V3_S0_FET_R=Pulses to 3.3V and goes back to 0,099V
PP3V3_S4SW_SNS=Pulses to 3.3V and goes back to 0V
PP5V_S0= pulses to 5v and goes back to 0V
PP3V3_S0SW_SSD_FET_R=Pulses to 3.3V and goes back to 0V
Check all SPI Bus Termination resistors and their traces.
Be sure J6100 is clean.
Just in case, you may try known good BIOS.
Check resistance between pins 17/18 and 27/28 of U7100.
Also check the sensor circuits from pages 41-43.
You can also try ultrasonic cleaner.
