820-00165 - no backlight
nelo1012
hey guys, '
i have a 820-00165 that has no backlight i have already replaced backlight filter (F7700), have also replaced LP8550, LCD Connector, Q7707, and nearly everything else around there, and back of the board,
and i know i should try to understand it, but i have spent hours on it and nothing, i still believe is something simple but you guys please help! :)
q7706
1- 8.6
2- 8.6
3- 2.82
4- 8.6
5- 8.6
6- 8.6
q7707
1- 0
2- 3.3
3- 0
4- 0
5- 3.3
6- 0
F7700
8.6 on both sides
thank you in advance
Post voltage on both pins of D7701.
Check XW7720 bridge integrity.
Use search function on the forum; pictures available too...
Post some voltages dor U7701; VIN; VDDIO, EN, PWM.
Use surrounding components as test points.
Did you check XW7720?
nelo1012
PWM - 0.57
EN- 2.83
VDDIO- couldnt find it
VIN- 8.58
and pardon my stupidity, but dont know how to check XW7720, i see it on the board view,
nelo1012
i removed R7704 and ran wire from BKL_EN to PWM, and no backlight, did reset pram a few times, and nothing,
also checked XW7720 , D7701 pin 1 to U7701 Pin 5, and there is continuity, so i think bridge integrity is ok, :(
Post resistance to ground on all U7701 connections.
That will denote a bad solder, if is the case.
Do you get image?
