820-00165 No Boot
Instafixx
PPBUS is at 8.44V
Fan Spins.
I have Magsafe light and it pulls 530 Amps on the PSU.
Work is done on the board previously.
SMC reflowed or changed.
Pin 8 of U1950 is connected to Pin 1 of C1950 via a jumper wire.
Instafixx
ALL SYS PWRGD is 3.3V
CPUVT PGOOD R IS 3.3V
SYS-PWROK R IS 3.4V
PM S0 PGOOD IS 3.4V
SMC DELAYED PWRGD IS 3.4V
PP3V42 IS 3.4V
RECONSTRUCTING TRACES ISNT REQUIRED AS ALL POINTS LOOKED OK AND ALL VOLTAGES WERE THERE I FEEL.
BUT IF YOU THINK IT NEEDS TO BE DONE THEN PLEASE GUIDE
I meant to reconstruct the traces as should be; separate pins 1 & 8.
Then post again the voltages.
PLT_RESET_L goes high?
Instafixx
How do i reconstruct the traces ? Pin 8 is going through the Pin of C1950.
Instafixx
Did that .
Not getting 3.42 on Pin 8.
The board point there is damaged and i think the jumper from C1950 was needed.
All_SYS_PWRGD is 3.3V
Rest all below 1V.
Mea culpa, you've mentioned pins 8 & 1 of U/C1950.
I was thinking both pins are from U1950.
Do you actually have 3V at pin 8?
Instafixx
SYS-PWROK R IS 3.4V
PM S0 PGOOD IS 3.4V
PP3V42 IS 3.4V
Voltages are stable till the time fan spins.
L7520 5V
L7560 3.3V
L7430 1.2V
L7630 1V
L7130 8.4V
L3095 0V
L7310/L7320 1.8V
THE FAN STOPS SPINING SOMETIMES WHEN THE PROBES TOUCH THE POINTS. ITS TOTALLY RANDOM
