Just got a rigol Ds1102e have no idea how to use it or what to look for but maybe you can give me some type of guidance on what to look for to hopefully get this going?
YouTube should have many videos about using o-scopes.
Apart of names, there is not too much difference between cheap digital o-scopes.
Usually, auto mode should be good enough.
https://www.eevblog.com/ has good reviews and explanations about million of electronic tools...
I think they have some tricks to extend frequency range too (by software).
pin 2,5 and 6 do show activity o-scope says 36v seems odd but multimeter shows 3.3v on those pins rest of the pins are 3.3v according to multimeter except pin 4 of course
ok well i had the max voltage too high o-scope showing 3.60v on those pins now. when i trigger smc_onoff_l i get a pulse but voltage stays the same. i do see a slight fluctuation of 3.60v to 3.80v on u6100.
does this mean the pch is not reading the bios then?
