820-00165 no green light when battery plugged in
laptopcity
820-00165 no green light when battery plugged in, when battery unplugged board works fine , will not work from the battery only , somehow i have 19v on R7006 even with D7005 removed which means somehow the charger voltage is going directly to the battery ??? , i cant see on the schematic where these two voltage lines may short together if D7005 is removed
