820-00165 No Keyboard Mouse
Instafixx
Macbook Air A1466. On/Off Button triggers but keyboard mouse not working.
Installed the board on a different chasis altogether to rule out any part issue. But still the same.
Also changed the flex but still the same.
Instafixx
Unable to enter boot menu or recovery mode because keyboard not responding. On/Off Button still works.
Keep them bypassed.
Do you get 3V at pin 1/J4800?
Check voltage at pins 12 & 15, before and after macOS started.
Instafixx
Before and After Macos Started
Pin 13 is 2.5V and Pin 15 is 3.3V
Getting Pin 3.4V on Pin 1
I dont know how i missed it but there is corrosion around C8000 and U8000.
Although diode mode reading of C8000 is 0.257
U8000 just fell off the board. Let me replace it and get back
Instafixx
Having a weird problem here. Some keys working when entering the password but not working post Macos login.
Example a,i 0 8 etc.
What can be the issue ?
