820-00165 no power a1466
hello i have a1466 no power no fan spin
got orange light
found abit corroded on RP2701
i just remove this then i clean the pads but still
cant on.
tried smc bypass no but no fan spin.
SMC_ONOFF_L 3.4v
PPBUS_G3H is 12.56
PP3V3_S0 missing
u7400 also corroded
voltage and diode to ground value:
6 0.0v 0.637
12 0.0v 0.411
16 0.0v 0.437
17 0.0v 0.495
i tried replace u7400 came from a1502 board still getting 0V on pin 6 12 16 17
So missing PM_SLP_SUS_L, no reason to search for S3/0 voltages.
Check S5_PWRGD, PM_DSW_PWRGD, PCH_DSWVRMEN, PM_BATLOW_L and all PCH's RTC signals.
S5_PWRGD 3.3v
PM_DSW_PWRGD 3.4v
PCH_DSWVRMEN 3.2v
PM_BATLOW_L 3.2v
not sure wheres all pch's rtc signal
PPVRTC_G3H 3.3v
PPVOUT_S0_PCH_DCPRTC 1.3v
please educate me. thanks ?
Did you read it?
I hope no need to remind the link on every thread...
This looks like PCH issue.
Put quality flux and heat it, in case of accumalated crap underneath.
180-200 degrees for 15-20s is good enough; you don't need to melt the balls.
You can heat entire CPU, but PCH area is the target there.
