820-00165 not charging
tech
PPBUS_G3H =8.17 only
Q7130 changed
U7100 chasnged
SMC reballed
SMC_BC_ACOK =3.3v
LIO board cable both changed
Incorrect PPBUS_G3H voltage; did you check it without battery connected?
Is the machine working, only not charging?
Check voltage and diode mode to ground on SCL/SDA lines of battery bus.
tech
SCL/SDA =3.3v present
machine full working only not charging
did you check it without battery connected? yes
