820-00165 possible chinese charger damage
Very clean board with the exception of a little blue around u6101. Magsafe green then orange.
Cleaned area with no change. Replaced u1900, u6101 and cleaned under u6100. All resistors around test good.
Mac came to me with a chinese charger so I switched attention to ISL. Replaced twice, no change. Just replaced SMC and again no change.
Anything else the charger could have killed?
8.57 on PPBUSG_3H
Apart of good PPBUS_G3H, you didn't post too much information to start helping you.
Do you get 3V3_S5/SUS at least?
Did you try to start in SMC bypass mode?
3V3_S5/SUS - both are 3.3v
smc bypass was tried while in the case and from the board.
Weird symptom - I get amber magsafe without I/O cable attached. This normally doesnt happen.
Test the board alone on the desk, no LIO flex connected, only 5 pins DC cable.
No SSD, airport, LCD or anything else.
Just check if voltages appear on big coils.
If present, check for pulse at all PM_SLP_Sx_L signals at same time.
PM_PWRBTN_L drops to .361 for a few seconds then back up.
PM_SLP_S5_L pulses on its own from 0v to .8v-1.3v every 5 seconds.
PM_SLP_S4_L pulses on its own from 0v to .8v-1.3v every 5 seconds.
PM_SLP_S3_L pulses on its own from 0v to .8v-1.3v every 5 seconds.
PM_SLP_S0_L pulses on its own from .06v to .8v-1.3v every 5 seconds.
Triggering SMC_ONOFF does nothing to PM_SLP
Swapped the SMC again from a working board. no change.
So power cycling every 5s, you didn't mention this in first post.
Check for pulse at all big coils at same time.
Also chek at pins 3 & 7 of U1950.
Big coils like L7320 are cycling. I guess I missed this. No fan FYI.
u1950 pin 7 is the same but pin 3 cycles only to .18v not as high as the others.
Fast pulse is not easy to ctach with DC voltmeter.
An o-scope can catch the peak level of any fast pulse.
PLT_RESET_L and CPU_VCCST_PWRGD pulsing too?
You can try known good BIOS, just in case.
