Jay
This machine came in as "no power", history unknown.
Connected to the PSU it drew a charge, fan would spin and CPU got warm. No POST or boot.
Took it apart and found corrosion on C0890 and C089, small spot. Cleaned it up and found one of the caps shorted to ground.
Replaced both caps and unit sat there dead. No PP3V3_SUS which I traced back to U8020 which sits right underneath the caps that were shorted. Replaced U8020.
At this point the MacBook was back to it's original behavior... fan spins, warm CPU, no POST etc.
Did an SMC reset and it fired right up! Showing the login screen.
Great! I shut it down to put the Wi-Fi card in and booted it holding "d" key for a hardware test.
back to original problem
Thought the battery looked a bit off, turns out to be a 3rd party, so grabbed an OEM KG battery to put in. Now unit draws no more than 0.800 amps and power cycles.
tested this with two KG batteries, same bahavior. Just as I'm about to give up for the day I put the 3rd party battery back in. It went back to drawing a full charge and now it power cycles and plays half of the boot chime on a loop.
Da hell... Before I spend tomorrow chasing my tail on this thing, any suggestions on where to look/what to look for? Apart from the small spot of corrosion the board was clean.
Appreciate any help
Appreciate any help
