820-00165 PP5V_S4RS3 missing
No-Clean
Board had minor corrosion near R6121 and U3220
M_BATLOW_L
M_DSW_PWRGD
CH_DSWVRMEN
M_RSMRST_L
M_PWRBTN_L
AND
P3V42_G3H
PBUS_G3H
PBUS_S5_HS_COMPUTING_ISNS
PBUS_S5_HS_OTHER_ISNS
PDCIN_G3H_ISOL
PVRTC_G3H] [p:C1910:1
P5V_S5
P3V3_S5
P3V3_SUS
All above rails are present and correct, PP5V_S4RS3 pulses every 3-4 seconds
"PP5V_S4RS3 pulses every 3-4 seconds"
Check for pulse at all other big coils.
Don't forget pages 57/58.
ALL_SYS_PWRGD pulsing too?
No-Clean
ALL_SYS_PWRGD pulses also
All other coils also pulse PPVCC_S0_CPU also pulses
Power FETs are all fine, I even reflowed the bga ones to make sure they are ok but no luck
PLT_RESET_L also pulses?
Check all SPI Bus Termination resistors and their traces.
Clean/remove J6100.
Inspect U6101 solders.
Try known good BIOS.
Reball SMC...
No-Clean
PLT_RESET_L pulses too
SPI resistors are all fine
J6100 already removed
SMC already reballed
BIOS was it, thanks!
