820-00165 PPBUS-G3H short to ground
Jay
Got a light on the charger but no power. PPBUS_G3H not present. I have 8.6V incoming on F7140 but 0V coming out.
Replaced F7140 and put the board back in the Mac, connected battery and smelt something burning. Upon checking F7140 I had 8.6V going in, 0V coming out. Not sure if it was F7140 that I smelled.
Checked for short to ground on pin 2 of F7140 and got one.
Now I'm injecting power to PPBUS_G3H (on pad 2 of F7140) but nothing gets hot or even warm. Went up to 8V and 2A but nothing.
What would the experts recommend I do/check next?
a few possibilities
1) cpu mosfet is shorted and voltage is going to the CPU, cpu still has heatsink on
2) it is one of the caps near the jtag or near the fuse itself
3) it is in the board and you are screwed.
Louis with the good news special! ;)
as this is my first time injecting a board, is there a rule as to how high I can go on V/A? Figured 8.6V was at that point anyway so it’s safe but Amps wise I don’t know.
Set to 8V 2A it only outputs 0.022V, is that enough to warm anything?
Will check cpu without heatsink and the mosfets next. Thanks!
Without heatsink, CPU does not get warm. Checked caps near jtag, don't get warm. No caps near the fuse itself except the ones feeding power into the fuse and those checked out.
Thanks for the explanation jadao. So Amps = always at max, then I start raising the Voltage (just repeating to be sure). Will try that.
Yes it's one method of finding shorts among others.
When you put Amps at maximum, let say 5A, it doesn't mean 5A are delivered into the circuit, it means 5A are available for the circuit if it needs it, now you will gradually increase the voltage 0.5V, 1V, 1.5V and so on until you feel something heating without exceeding the limit of the power rail shown in the schematic.
When you gradually increase the voltage you should see and monitor amps display on the PS, it will increase depending on what the circuit is taking (we don't know how much current it will take so we just set it to max and control the voltage). Usually you don't need to reach the maximum amp to find the short except when nothing heats up and you are desperate and think the short is internal to the board.
It's just a matter of power Watts=Amps X voltage. For axample, if your shorted component on a 12V power rail start to heat at 3V, 1.5A (3*1.5=4.5Watts) someone else could have the same result with the same shorted component starting to heat with 2.25V and 2A (2.25*2=4.5Watts)
Now for normal operation, if you have a known working device at 12Vdc 0.5A, of course you just set the voltage to 12Vdc and limit the current for good practice to 0.5A but even if you put 5A, if the device is not faulty (shorts) it will not take more than 0.5A.
I really hope I didn't bring more confusion :confused:
Small correction, you need to increase Amperage. Wattage will not heat things up, its the amparage that will.
Always use a as low voltage as possible and only increase the voltage if you can't increase the amps anymore due to the voltage stabilizing
I probably should've made a full reply about this, but I just wanted to add that you should always start with the lowest voltage possible and going above ~1.75V on PPBUS lines can be risky in case its leaking away into the GPU or CPU (Which is probably good for 1/5th of the PPBUS shorts). Otherwise good explanation!
By increasing Current (Amps) you are increasing the power (watts)!
By increasing the voltage (Volts) you are increasing the power (watts)!
Of course it's a matter of power dissipation, of heating energy resulting both from voltage AND amperage.
When you are looking to find a short you are looking to feel the heat so you are looking to create a power dissipation!
Now, how to create this power dissipation that will let you find your short?
By setting a voltage and a current.
When you started this post there was 8.6V present. Remove F7140 again and see if it comes back, else something got fucked.
Tested with other I/O board, same issue. PPBUS_G3H = 8.6V. PP3V42_G3H = 3.4V. (same values with or without cable) and connectors look good on both ends.
It is but only with the ribbon cable connected. Without the cable the unit boots but magsafe shows no light.
